- Vacaville Ca
Thank you jetmaniac for the 61x stator. Now my ski is running again. Great customer service and fast shipping!
Sent from my SAMSUNG-SM-G900A using Tapatalk
Do you have any 62T cdi"s available?
Thank you!
I would like to order a 61x used cdi and a voltage regulator
Any OEM 61x CDI available?
OEM Stators and Lightened Flywheels
61x OEM lightened flywheel 119.
(Approx. 1/2 lb. of rotating mass removed)
61x OEM stator 129.
(Clean used, tested, 30 day exchange warranty)
62t OEM lightened flywheel 179.
62t OEM stator 189.
New 62t OEM stator 605. sale 548.
Jetnetics 62t billet lightweight flywheel
Cold Fusion billet flywheel lock tool 49.
Flywheel puller tool 29.
New Flywheel cover gasket 12.
Woodruff key for flywheel OEM Yamaha 6.
Flywheel bolt OEM Yamaha SJ new 25. sale 19.95
Flywheel bolt OEM Yamaha couch used 9.50
Blank OEM stator grommet to cases/flycover 9.
Threebond 1211 High Temp, Hi quality silicone sealer 19.50
(great for both flywheel cover gasket and for starter nose as well as between crankcase halves.)
Under the flywheel cover hardware kit 35.
(OEM flywheel bolt, stator bolts, flywheel woodruff key, bendix front cover spring and washers- all OEM clean, used parts)
Maniac SS Allen flywheel cover bolt kit 13.
(7 SS bolts with SS washers)
Oil injection blockoff kit 13.
Starters
Aftermarket starters don't last and aren't as powerful as OEM Mitsuba starters. But new OEM starters are really expensive from Yamaha so JetManiac is rebuilding clean oem starters to fill the gap between new oem and a/m starters. They are totally disassembled, cleaned and rebuilt as necessary and finished with multiple coats of black satin epoxy paint.
OEM JM rebuilt starter for Yamaha 701 185.
*Tested to work and includes a 6 month exchange warranty.
(water intrusion thru nose is not covered.)
*Add extended warranty for 1 year 20.
OEM JM rebuilt starter for Yamaha 800 PV, 1100/1200 non PV 179.
OEM JM rebuilt starter for Kawasaki 179.
New OEM Yamaha starter 449. Discount to 389.
JM OEM Yamaha 701 starter 115.
(clean freshwater starter, cleaned, inspected, lubed and tested, 60 day exchange warranty)
New SBT Hi-Torque Starter 129.90
(1 year warranty)
Fits Yamaha 650, 701, and 760cc motors
*add SS allen starter bolt install kit 5.
(stainless allen bolts with locking and flat washers)
Starter parts:
Replacement Starter nose O-ring OEM 8. Discount to 5.95
Replacement Starter nose O-ring a/m 2.50
Starter OEM rubber seals 7./ea
(seal between center section and front and rear sections- 2 needed)
Bendix (aka: starter drive, idle gear comp.)
Again, aftermarket bendix just aren't up to OEM quality but are really expensive new. Failures of OEM bendix are usually due to water intrusion or the inner metal weight plate ears breaking off allowing the weights to move around, and then break their locating spring allowing bendix to stick open.
JetManiac OEM bendix are inspected for inner weight plate having all 3 ears intact, teeth and end surface condition, etc. finally they are cycled repeatedly to check action and lubed with special Corrosion X HD. Many are rejected for various other issues. Only nice clean ones are used.
(bgrade cosmetic available for less)
**If you have had bendix issues or are building a new motor, also make sure to check the soft bushings in the crankcase and inside the flywheel cover. Bendix should go in relatively tight and not rock much at all from side to side. The case side is especially prone to wear.
JM OEM bendix $59.90
*Tested/inspected/lubricated and come with a 4 month exchange warranty
(water intrusion is not covered.)
New OEM bendix 387. Discount to 298.
Bendix installation parts:
Bendix bushing OEM- for crankcase or flywheel cover 9.90
Bendix bushing a/m- for crankcase or flywheel cover 4.90
Bendix front cover spring 7.50
Bendix front washer-smaller, thick for each side of front cover bendix spring- OEM 2.15/ea.
Bendix rear washer-larger, thin for bendix to crankcase -OEM 4.95
Bendix repair parts:
OEM bendix weight spacer plate 12.95
(Replaces frequently broken internal plate that spaces the 3 weights. Broken ears are common and one of the causes of the dreaded 'bendix grenade.')
OEM bendix internal spring to hold weights 10.75
Billet Flywheel Covers
(all of these billet covers use oring instead of paper gasket)
Cold Fusion SILVER or BLACK anodized billet flywheel cover 159.
(fits yamaha 650, 701 both 61x and 62t cases)
JetManiac anodized billet Yamaha flywheel cover 159.
(available in black, silver, red, blue, and green)
Reusable Oring included.
These flywheel covers fit Yamaha 650, 701,and 760 cases with OEM 650 6m6, 701 61x, or 701 62t electrics or MSD total loss setups.
Add JM SS allen head flywheel cover bling bolt kit 13.
SB Products Billet annodized colored flywheel covers with clear lexan windows 259.
I need starter and bendix
been on site a whileOEM Stators and Lightened Flywheels
61x OEM stator 129.
62t OEM stator 189.
New 62t OEM stator 605. sale 498.50
Jetinetics 62t billet lightweight flywheel
Starters
Yamaha 650/701/760 Starters
(1 year warranty)
Yamaha 800 (XS1200), 1100/1200/1200PV, 1300PV Starters
OEM JM rebuilt starter for Yamaha 800 PV, 1100/1200, 1200 PV 169.
JM OEM Yamaha 800 PV, 1100/1200, 1200 PV starter 96.
Kawasaki Starters
OEM JM rebuilt starter for Kawasaki 650/750/800 169.
Starter parts:
JetManiac anodized billet Yamaha flywheel cover 159.90
Sorry didn't finish I am looking to light b a brand new total loss mad flywheel is this something you could help me with?Hello
Looking to lighten a msd tl flywheel brand new in box stillSorry didn't finish I am looking to light b a brand new total loss mad flywheel is this something you could help me with?
Thats a sexy box!
