KTM434
Jamie FN Hickey
- Palm Coast FL
I'm curious to hear some ride reviews.
Let's hear yours..,
The hull is 13.5 inches shorter than a superjet. The bottom deck is based off an sxr but then everything has been changed. The keel is wider(for those who don't know what a keel is its the part in the middle of the bottom of the ski that runs length wise) The front chines were also re-designed and are wider, and the rear chines are less aggressive than the sxr (less edgy) so it doesn't have that bite into the water like an sxr has. Bottom deck has front rocker and rear rocker as well as front sponsons. Theres more for sure but I know this much...Since the backie chan thread is closed, I'll ask here.
The bottom deck is based off a SXR correct? Does that mean the width is the same as a SXR? If not, what is the width and length?
Your paint is off the chain!!! Saw it yesterday and the pic you have don't do it justice. Wait till you see the next one that's coming out of the paint booth, going to be a little different but hope y'all like the color combos. And...... you will get to see a chan with a recessed front foothold( that will act as a coupler cover and will be able to have a stock e-box mounted horizontally on top of the ffh, its pretty trickThe BC thread is closed???
In the thread in the New Products section, Steve mentioned how much running length the BC had. Can't believe this thread is on page 6.
Now about the hull . The bottom is based off a Sxr ...cut short as hell ,,front rocker ,rear rocker ,Wider ,different tubbies ... Yamaha pump and intake track . It takes a 2 inch extended intake grate but we have inserts for the mold to go a plus 4 ... I will say thou the readability with bigger then a plus 2 intake is very very strictly flat water ...it will also except up to a 160 pump as that's the biggest we tested ...the rear has a full width ride plate to change the attitude of how it rides and you can play with length for your weight ... The hull with flush plate has a 71 inch running surface .. The overall is 77 inch tip to tip ...
Your paint is off the chain!!! Saw it yesterday and the pic you have don't do it justice. Wait till you see the next one that's coming out of the paint booth, going to be a little different but hope y'all like the color combos. And...... you will get to see a chan with a recessed front foothold( that will act as a coupler cover and will be able to have a stock e-box mounted horizontally on top of the ffh, its pretty trick)
Its gonna be a biotch to shim and check the gaps on the coupler....
