SXR Kawasaki 800 SX-R Project - Weigt, Engine and Hull
Hi all ( following Thread will be updatet during the winter )
I have had my SX-R 2006 for almost 5 years now and i love it. Everyone i talked to tell me that the ski is a lot funnier with Head And Pipe.
I am now building my ski with several mods. Hope you comment it and will follow the build up.
The plan is following ( and all the parts is bourght:
Hull:
Weight reduction ( startet and on 21lbs )
Carbon reinforced hull
Blowsion 2 Tubbies
Umi steering
hand warmers
Blowsion foothuls
Bilge pump
Several blowsion fittings
Drain plug
Shread Master Carbon Rideplate
TBM Grate
SOLAS impeller
Bored Nozzle
Bored Exit Nozzle
Hydroturf
Engine:
Stock Bore
Stock Crank
Stock Pistons
R&D TOP END 165 PSI
Carb with no choker
Primer
R&D filter kit
Facotry B-pipe (wet ) And manifold
Water steering on exhaust
Protec Ignition
6' Timing advance
Polished carb intake
Now the pictures of the build:
IMG_2021.jpgIMG_2018.jpgIMG_2020.jpgIMG_2766.jpgIMG_2769.jpgIMG_2771.jpgIMG_2774.jpgIMG_2776.jpgIMG_2778.jpgIMG_2791.jpg
tomski
X
LHC
I would check the position of the front sponsons before installing.
Hi guys - You can see the duck tape on the picture :) it was just to se how the tubbies looks on the sxr. :) I will post a new picture where they are mountet.
Have any of you guys reinforced the sxr?
Texan33
Yacht Wakes Hunter
Texas
We were just looking out for you. Sounds good.
No need to reinforce the sxr. They built like a tank. I noticed you started to sand down the hull. How much are you sanding off and where? The bottom or the sides?
Thanks mate ! I know you are :)
I have a small crack in the hull where the hull is glued together after a atemp to barrel-roll it. Thats the reason to make it stronger with Carbon.
Texan33
Yacht Wakes Hunter
Texas
Cool pictures. Do you have a picture of the crack? My SXR has two stress cracks on the left side from a few failed barrel rolls. It looks like the fiberglass is cracking but it's actually just the gel coat. The SXR hull are built like a tank. Matt Smith's SXR is the only one I have see with a crack through the hull.
If you see the pictures in the top, next to the Tubbie's pictures, there you can se light trough the hull. ( IT LANDED HARD - My shoulder was in pain next 3 days ;) )
Progress:
Carbon & Reinforcing - Later today Black coating.
IMG_0754.jpgIMG_0755.jpgIMG_0756.jpgIMG_0757.jpgIMG_0758.jpgIMG_0759.jpgIMG_0760.jpgIMG_0761.jpgIMG_0762.jpgIMG_0764.jpg
