If you are going to buy it stock, and leave it stock, the Superjet is pretty boring. You can do plenty in the surf, and you can do subs, turn subs, maybe some 180 or nose stabs on the flatwater if you have the skill to do such. A lot can be done using momentum.
I ride bouys with a lot of sxr of various levels of modifications and my Superjet sucked to race when it was stock. It relies too much on momentum and comes out of the water too easy in heavy chop. The pump comes unhooked and cavitates and doesn't have the power to keep going. I'd come it on a piece of chop and come to a near stop when I bashed into the next piece of chop. It also doesn't carve very well.
The stock Superjet prop is aluminum and very large. In needs to be replaced or you can expect a lot of cavitation. You also really need a pipe to wake the motor up. It doesn't carve very well without front and rear sponsons (unless you get an 08+ which carves very well).
With a full limited, set up for rec riding (49mph, a balance between bottom and top in my tuning and prop), I struggle to pass stock sxr, I tire out much sooner than the guys on the sxr and I can't ever get near a pass on a limited sxr (although I can box them out and prevent the pass, but I fatigue much sooner, sxr easier to ride)
For every disadvantage the Superjet has in racing, it makes up for it in versatiliting. I can get 3' or so now off my own setup wake. I can easily double the height the limited SXRs can get, but they are proper strictly for racing so its a bit tough to compare exactly.
If you goal is to cruise and carve whiling staying stock, the sxr is the hands down winner. If you will upgrade a pipe, head, prop, etc, the Superjet wins on versatility.
