- South Africa
Hi guys, are there any kawidoo freeriders out there
??? Mines finished in 2 weeks... Freeriding in cape town only July:thinkerg: freshwater till then ;<
I am working on putting a 787 in my X2,the 951 is just too much work to make fit plus it weighs a ton,the 787 weighs a lot less,when done I should easily be around 130-140 hp.
Yes but if you put the same stuff on an engine that starts at 130 instead of 110, you certainly wouldn't be worse off...
Only the older 951's are unreliable. I think a 787 with a head, pipe, flame arrestors and total loss will be less reliable, compared to a bone stock 951. Plus, you'll never beat on a 951 in a standup like they are beat on in couches.
They aren't gonna run WOT for 1/2 hour straight. Should be VERY reliable. Especially running completely stock.
The issue of the LOWERED intake from the carbs is still the problem. You will need a serious snorkel or it will hydrolock after the first sub.
