another piece of info from mark on turfing, might help some of the newcomers out
The glue will stick to the paper if too much pressure is applied, I would recommend using pop sickle sticks then you can just pull them out and let them hit the floor while you are working the turf. The heat helps the turf be more pliable and easier to apply it to the contours.
The same system applies to the bond rails, glue heat and apply. I always cut the edge that meets up with the side of the ski on a 45 deg also; this gives the edge a real clean and flush look the taper is away from the ski with the top diamond edge touching the ski and the bottom edge away from the ski. If that makes sense to you.
Now you cut off the access under the bond line with the 45 up so the water doesn't catch the edge. You can also super glue around the edge to really seal it that will be Jon's job not mine
Next we will turf the tray, remember HEAT and HAMMER. Oh yea, beer helps too.
Again, if you think it's dry leave and come back in a few.
Mark44
