Bam, rode the biatch through probably a little more than 3 gallons yesterday.
Engine seemed OK, did a little tuning with the new carbs. Both plugs were pretty even when I looked at them and richened up a bit to be safe as they looked a little grey. Was hard to tell since they were so new though, need a bit more time on 'em. Engine has good pop and power, will just stand on the jet. Once again I could only just bloop because of other issues though. I looked like a little nerd, but had fun anyway haha.
So, other issues are:
OEM Yamaha 760 intake clearance is pretty bad. I need to cut the hood back some more, but I'll try to get some pics of it later. Since there are so few of these out there it is a long shot, but anyone running a OEM intake on their Footrocket? I love it other than that, even with my water issues I finally didn't ingest any into the engine.
Hood seal is useless. I tightened the front pin so much that I couldn't get the hood off without a screw driver and basically sitting on it to compress it. And it still got copious amounts of water in it. Is there an aftermarket hood seal anyone can recommend that works better? Any time the front went under the hull filled with water so I had to be careful-ish and try to keep the nose up.
I'm getting a ton of water in from the back pump area. I already sealed my scupper, but I think it is coming through the trim and throttle connections? I didn't think it would allow that much water in, but if it sits for a couple minutes on shore it seems to fill up enough to let my bilge pump pump out a huge stream for 5-10 seconds or so.
That seems about it for stuff keeping me from really riding it. I do hate the throttle lever, guess I am spoiled from the UMI one I've always had on my skis. The Kavinci lever takes so much effort to pull and the sharpness is lame.
Anyway, here are some riding pics
And I uploaded a 120fps slomo video to FB...not sure how to embed it here. Here is the link to FB:
And if that doesn't work I embedded it at the bottom of the page on my blog:
http://www.chixwithtrix.com/2016/12/07/krash-50-cal-footrocket-freestyle-build/
