Now that I have a moment I wanted to post some pics and get the thread up to speed.
Working with Krash on the hood damage. Trying to get a quote to get it repainted, but with life crap getting in the way I haven't been able to go somewhere and check. I am doubtful they would be able to color match it though.
When I received the hull the impeller was dragging in the pump, even with a ton of grease in there...
Pulled off the midshaft and alignment looked decent. Pulled the pump out, by having to disassemble it, and it was indeed rubbing. Talked to Nick and he said it was tweaked because of mis-shimming. It had two .40mm shims on each of the front mounts. Says it needs to be reshimmed and put back together to be good to go...
Impeller was also bent at the top
