khaos
Party in a can!
- Tidewater, VA
Thanks. Is there a surf bottom and a flat water bottom which are different in the 50Cal? And if so which did you get?
I got the surf hull.
EDIT: (Found it)
Model..............Length (bare)... Width (bare)......Draft (bare)
50 Cal Flatwater....1985mm / 78”......605mm / 23.8”....172mm / 6.8”
50 Cal Surf.........1990mm /78.25”....645mm / 25.4”....146mm / 5.8”
"The wider tray and hull makes the 50Cal so much more stable in rough choppy water and the bottom curve and design and forth chime on the surf model means that it carves the waves like a surfboard, whereas the 50 Cal Flat water’s narrower beam, deeper draft and release rocker and unlimited power of the KV 997 means that the rider can flip and roll like the hull was on the rails of a roller-coaster no matter what the water conditions."
~Krash
