how much does this thing weigh?
About 66/70 lbs Iv been wanting to get out there and ride more but the weather isnt working out
I hope to get it back out this weeken with a ride vid. I have 4 gal run threw it so far, next ride ill be leaning it out a bit now that motor is boke in. Riding this boat and doing anything on it is a learning curve in its self due to its shortness...the xfs/and BOB owners Probably know what im talking about. For the most part iv mastered riding the boat to a aggressive level. No flips yet, attempts 2wice...during
the last ride gal#4. Trust me this is on my 2DO list!!
Ok, this boat is alot shorter than my q8 buy about 2 1/2 inchs. They are both sxr's with nose changes. q8 has tug boat nose that aids the nose in staying up ready for flips, hull super short in engine bay area while rear of hull isnt drasticly cut. Lenzi hull has a much wider flat nose to capture water for lift, longer engine bay area with a drastic cut off rear. So you can see both are effective in there
own ways. The q8 was easier to ride in a way, I say this only because it is longer hull wise in rear. They q8 slides more into corners, the Lenzi is the opposite
I was surprised how it cuts quick with not much sliding into setup wake. Lenzi feels normal to corner, q8 in nose felt...different all i can say on that. So far working on the boat Lenzi wins, its a breeze with how low/wide the engine bay is, working on pump made easy since its hanging off the back with no hull in the way...watch out coming into shore tho. q8 was a very tight engine bay...not fun to work on if issue
came up. This is what iv come up with on both boats.
