What are some of the most important lessons you learned during rebuilds?
There's a saying that good judgment comes from bad experience, and a lot of that comes from bad judgment. So what were some of your mistakes, regrets, or lessons learned? Which products or tools did you regret using during your rebuilds?
I'll start....
- Removing the flywheel with a gear puller simply doesn't work. A harmonic balance puller is a must!
- Threading harmonic ballance puller bolts too much into th flywheel will damage the stator.
I'll start....
