lets have some pipe reviews
Legdragger
Bringing it back
New Hampshire
I had the Coffman that looked just like the R&D Slut had. It was reliable, easy to install and made like 8 hp supposedly. For the money it was great. One thing I like about it over stock was it lowered the center of gravity. I thik it is still in the attick.
Anyone......... ?
Has anyone ever tried a Wetjet 701 pipe?? I have two of them and they look well made ( I think Westcoast made them?). I'm not sure how/if it would fit though. I think at the least it would have to have the stinger cut and rewelded to point in the right direction. I've heard rumurs they make more power than stock??
IceRocket1286
Metro Detroit
I originally had a FPP Type 4 dry pipe on my squarenose, and i liked it more than the B pipe I have now. I only changed because I kept blowing couplers and the alignment is horrible on them....and wet pipes are more reliable.
I do like the speedwerx dry pipe the most though. It rips from bottom to top.
WaveDemon
Not Dead - Notable Member
Hell, Florida
I figured I'd bump this up.
I tried to do a cheaper version of the b-pipe. I started with a coffman manifold and ported it. I couldn't get the chamber in without denting it. I think the angle of the 3 manifold bolts are off a little and mis-aligned the chamber. If you're willing to clearance the chamber or ride a ski with more clearance this might work.
The other thing I did was take a head pipe with 3 bad screws and drilled out all 3 to a size WAY bigger. I had Tom21 weld one shut, I put a giant bolt in the second one, and put a water injector in the 3rd. I put a brass valve right in front of the water injector to adjust the water flow.
The chamber I already had.
TOBY
BNA
NashVegas
GP 800 pipe/suoerjet
I wonted to try and see if it would work/fit its a GP800 with 1300R non PV cylenders 84mm bore 62T totaloss pickup and flywheel, carbs are 46SBN running pumpgass. I had a yamaha B-pipe i sold the manifold bought a new SXR wetpipe manifold, me and a friend made the adapters i then drilled the water passages in them installed a .5 waterline and re drilled the pump that line feeds the manifold and a .375(OEM) feeds the headpipe. it was a fun project/cool. im also using 62t bedplates hope you enjoy
WaveDemon
Hell, Florida
anyone have any tips or tricks to get more power out of the Pro-Tec Mach 1 pipe. This one has no water screws. I was thinking of restricting the inlet water to try drying it out.
brett
Ventura,ca
the coffmans sizzler i put on my brothers stock 61x motor works really well and makes great low-end. i bored out the exhaust mani to fit the exhaust port and bolted it on. i know you can dry the out a little bit too but it works great for a stock motor...good luck findin them
attachment.php
I still love the coffman sizzle ma dizzle and i think for the price its a great alternative to the B-pipe
I picked up a rather rare pipe last year for a rebuild named PSI similar to protec style but snow mobile manufacturer...
Also ran protec for 650 was medium impressed, & ran different style of B-pipes MOD/limited chambers
piratelife
Frandsen works
In the hood wood
Has anyone ran a coffman sizzler that has been opened up to 47 mm on the head pipe and exhaust manifold? I had this done to mine but i never ended up trying it. I ended up buying a b pipe instead. But i still plan on maybe using this on a budget build for my wife. I think stock it was 42 mm Im guessing this is why some people say they dont work as well with the 61x case.
dfw
The Sizzler is a good pipe. Make sure to match the manifold to the cylinder and use an OEM Kawasaki 650 bushing. Power wise it goes 48mph at 6860rpm on a 61X/61X @701CC, cyl mildly ported.
