I win, A123 26650 4s2p battery (same cells as in a tesla roadster) $85 shipped. If the capacity isn't enough you can get a 4s3p battery (4 in series [determines voltage], 3 series in parallel [determines capacity] that holds more energy in less weight than a deka 9. Cost is slightly more but justafiably so. You would need a connector and maybe a special charger. My next battery will be one of these.
a123 4s2p
Weight 1.43lb
Volts 13.2
Amp-Hour 4.6
Continuous A 138
Peak A 276
Width 4"
Height 2.75"
Depth 2"
EXT-9
Weight 5.4lb
Volts 12
Amp-Hour 8
CCA 120
Length 6"
Width 3.44"
Height 4.19"
a123 4s2p
Weight 1.43lb
Volts 13.2
Amp-Hour 4.6
Continuous A 138
Peak A 276
Width 4"
Height 2.75"
Depth 2"
EXT-9
Weight 5.4lb
Volts 12
Amp-Hour 8
CCA 120
Length 6"
Width 3.44"
Height 4.19"
