The exhaust is what kills the idea of the 1000 for me. B-pipe restricts power and PFP requires smaller tank. :dunno:
My SS865 should be shipping early next week. :Banane13:
you can run a bpipe with a 1000.....From what I remember Chuckie told me that the B actually will produce MORE bottom end vs. a PFP..
BUT
the PFP makes it more linear and controllable
those insanely huge reentry's that TC was throwing was with a 1000, bpipe and enhancer..
my argument for it is the same as madmat's
"why not?"
if your going to go all out...go all out..
the price difference is really not that much...you can run the same 46mm carbs, Bpipe and an enhancer..
the 10mm crank is about 1200 bucks...a new OEM is 600-700
the cost is the same (roughly) to rebuild...I dont think piston wear is an issue here...If the thunder pumpkin can go 3 seasons on a set of pistons then a rec boat should go the same or more
the 1000cc costs roughly 300 more (I think) in machinework vs. the 865
the major price difference comes in if you want to run a PFP
with this you are going to need dual 49 full specs, and will likely be running TL and race fuel (c12)
the 1000 will cost a little more to build....but the cost will be irrelavent in the long run....
I love my 785 mighy scream with the single 49 full spec...but the next motor I do build will absolutly go 1000cc..
now, ALLLLL that being said....you cannot go wrong with the 865 either..thats insane power on a stock stroke!
just make sure to set it up PRECISELY the way TS tells you....
I have ridden 3-4 of these motors back to back and you can absolutley tell which ones are setup to the exact spec..
