- Pueblo, CO
so you found a 144 mag prop that works well? Wich one, Toby wants to try it w/ his TBM.
Skat mag prop: C+75 (144mm) pitched to 12/15 by Impros. But I still need to bore my nozzle to get the most out of it.
Im running a 16-20
but i have alot of hp in this engine
so i am not sure what you would need
My ski will rip off the bottom
I am running a 16/21 in my mag pump and it hits nice, gonna try a 14/19 if I can find one.
We have a 15/20 pitched down to 15/19 skat swirl (big hub) we are going to try w/ the TBM on Toby's 5mm stroke ADA set up, will keep you posted on outcome.
Charles (crammit442) and I had a pump swap day where we played with various versions of the 140 mag pumps and Skat props. By far the hardest hitting setup was a 13/21 Skat swirl in a 12 vane setback. However, it was only a little better than the 14/21 (in my opinion it wasn't worth the loss in top speed for the minimal gain over the 14). I had been running a 15/23 in my 14 vane setback and changing to the 14/21 was a night and day difference. Although the 14/21 was in a 12 vane (we didn't swap props into the different pumps) I don't think there is a big difference between 12 and 14 vane pumps.
Wax, I am surprised that you are running a 16/20. Have you tried a 14 or 15 primary? Are you doing this in a race boat? Our boats weren't too shabby in the power department either and the 13 and 14's really made a difference on arm-pulling power to the water. The 15 and 16's really drag it down relatively speaking.
The prop I had in my boat that you rode at Lanier was a 14/23 w/stock nozzle and med cone. Bored nozzle to 83 and still runs out good. I also got a 13/21 and it comes on even sooner and still runs out good also. Hits a good bit harder than it did at Lanier. Using an 83mm nozzle with it also. No slippage that I can feel. Still using the med skat cone.
Charles
Hmmmmmm, wonder why not many freestylers use them now!!!!!!!!!!!!!
If you got the power to overcome the weight, then it ok... (Malone, Lenzi, and others of that calibre).
TBM is pretty light.
That's it.
Lenzi are always looking to save weight and increase weight to power ratio but he never think about to use OEM pump.
I think that if he knows there's something like TBM cone and mag prop use option, he might think about that.
Ive been running mag's for about 2 years only. I got some used/new cond props but never played with that since the magnum gives U an awesome handle that U become a little lazy to change props.
On our stock stroke Lameys PV and NPV, the 13/18 140mm has been doing a great job. I got some very long 16/23 (I guess) and it is awesome on a 6 mm oem cylinder for racing. (I wanna try something shorter)... I got a prop from Nikad last year and I wanna try it. The pitch is 14/21.
So... the Mag pump in my opinion are like big carbs (Novi, FS and Powerbombs)... even if it is wrong setup it is awesome and better than oem or cheaper carbs perfect adjusted.
Just half a cent
Gera
Same guy that use to race a Squarenose!
godocgo!!!!!!
My cone looks huge, not sure wich one it is though? I loved the way yours hit in Lanier, but U got total loss so not sure my set up would be same. Did you ride mine in Lanier?
so after reading this post i take it that solas does not make a "bigger hub" style prop like skat-trak does but the solas still will work with the tbm super pump cone. also the c-75 skat swirl prop has a bigger hub size that will match up to the increased pump hub size that the tbm offers. that is why skat is being recommended for best results with tbm cone, but not absolute necessary. Stock pump size is 144 and mag pumps are 140 and or 144. The 140 magnum is a race pump and weighs much more then the 144 magnum or stock pump. i also heard or read that 1% pump efficeincy increase is equal to 10% hp increase. Do i have all this right? (besides spelling) If so it looks like this tbm pump cone is a good mod to consider.
