I guess I'll write up the flanging process real quick.
3/4" XPS panel traced around the deck, then measured 2" in and cut the inside out. Measured the outside to 6", then cut the excess off.
Gorilla glue and random piece of concrete, wood, and steel to create pressure on the XPS.
Misted the XPS with a rattle can primer. The primer dissolves the XPS slightly, but also creates a base to layer the bondo over. Without the primer, the bondo wouldn't adhere well to the XPS and would almost eat through it. I chose the primer over just epoxying the XPS because I didn't want to wait 24 hours to start laying the body filler. Epoxy would be a much better choice for this purpose though.
Pin holes filled with glazing putty and sanded down to 150.
So the first can of Duratec I bought wasn't mixed on a paint shaker prior to shipment. I didn't know this and only mixed the top portion of the can before spraying the hood plug. When I got down half way I realized that the solids had separated and I shot mainly the much less viscous portion of the product. In an attempt to salvage what was left, I mixed in a quarter of a new can and then thinned the mixture with 10% MEK and attempted to shoot it. It laid down OK, but it never really atomized the way it should have and created a nasty orange peel along with some chunks of solids. At this point I could either attempt to strip down what I shot with acetone, or let it cure and then sand down to 150 again, or continue shooting and deal with the textured finish later. I decided to finish shooting with the new can of Duratec. And as expected, a nice textured, matte finish.
Lesson learned, check the date on the Duratec and use a paint mixer.
Sanded down to 400, then 1000 tonight. Probably needs to be hit a little longer with 1000, but I can't tell in the dark where at.
I will get it molded over the weekend and a part out of it next week. Hopefully my carbon order arrives tomorrow.
