With the ride plate mold done, I can get to shortening the hull and creating the recessed plate area for the full width plate. There's several ways to go about creating the recess. After a lot of thought I chose to fill the negative space inside the hull with glass and then pull a foam mold off of it. This turned out to be incredibly time consuming...
Started by marking the inside of the hull and measuring where the glass would go.
18 12"x6.5" (i think it was 6.5...) sections of 1708 biax measured out and cut.
Layered down a thick coating of epoxy/cabosil before laying up 9 pieces of 1708 per side. I used a cabosil thickened epoxy for wet out to help build up to the height I needed. About 1/3 the consistency of the "peanut butter" mix. I actually like this over straight epoxy. It holds the biax around bends/corners better.
Using 1/4" particle board I cut out the rough shape of the hull and attached 2x4 pieces to secure to the pump area and offset the particle board from where the ride plate recess would be.
2mil plastic drop cloth laid in the hull and fitted around the particle board dam.
Pour foam in. Took about 12 oz of foam per side.
Removed the dam and plastic and replaced the foam mold. Measured out the cuts, 7.5" off the back. Removed the foam and made three more cuts on each side for the ride plate.
Prepped the glass area. Sanded with 80 grit, MEK to clear out any dust. Duct tape over the inserts to keep epoxy out. Foam back in place. Clay to fill in the gaps and somewhat form the shape.
Wax paper to release the foam after the glass is set.
Cut 3 12x8" pieces and 2 10x8" pieces of 1708 per side. Measured out the relief cuts as best I could. Had to make a few cuts while laying up, but it was pretty close.
Layered on some heavily thickened resin over the wax paper and around all of the edges. Used lightly thickened epoxy to wet out the 1708. Once the 1708 was down, cabosil/epoxy in the joint between the two sets of glass, then 2 layers of 8oz 3" wide tape to tie them together. Same thing for the side where the ride plate will sit.
