- Houston, TX
For the enlarged pump tunnel the plan is to pull a foam mold off of the current tunnel, then sand/cut out the mold. After that's finished, pour foam inside the mold to create a positive mold which will have glass laid over it.
Created an enclosure for the foam.
Tape to secure the plastic.
Foam in. 12oz wasn't quite enough.
Because I didn't use enough foam there wasn't enough pressure to push against the plastic and grab the shape. I had to pull out the plastic, duct tape the tunnel, pour more foam over the duct tape, then place the first foam mold on top, add more foam and place the top back on. While the foam doesn't really stick to the duct tape, there seems to be a higher surface tension (or something) because it was a b*tch to get off this time.
