- Houston, TX
Made a little progress on the nose. Used a 1/8" steel rod to make the bow line. Screws and washers to hold the rod in place and adjust the angle. Foam blocks on top of the exposed screws. Safety first... more like a safety afterthought since I probably stabbed myself 5 or 6 times first.
Total length of the hull will be 76" nose to rear bond line. I could take another 2" off the rear bond line if I really wanted to. This makes it -12" from stock (current year model).
Created a foam block from XPS sheets. Used 3m super 80 to adhere the panels. Stuffed it down in the nose. Using the steel rod as a guide I cut the block down with a sawzall.
Sanded the foam and SMC down to a rough idea of what I want, then layered on some body filler.
That's where she sits for now. I want to reduce the nose angle so it transitions better. Also want to reduce the center in the rockered area a bit so it isn't quite so far below the sides of the hull. You can see that little "bubble" like section in last picture right above the 90* elbows on the PVC stand.
