- Houston, TX
Sprayed the tubby plugs with a high gloss enamel and made some progress on the top deck today.
You can really see how much shorter the bottom deck is here.
I like the sano sticker on this pile of poo.
Measured and marked off the gunwales to lower them down to 5.5" from the rails. That's about 2" lower by the bulkhead and 3-4" at the tail.
The triangle marked off in the front corner is gone and that area is going to be nearly 90* in relation to the bond rail. The line where the gunwales are cut off extends almost all the way to the nose. The area above the line will be cut off/sanded out and glassed/bondo to be at a small angle to the side below it. Where the latch/reserve switch area is, the top of gunwale line is going to curve and blend into that.
Bonded some XPS together today, hopefully I can get some of the nose shaped up tomorrow while the tubby molds cure.
Speaking of the top deck nose, I need the measurements from a freak for the pole mounting bracket. I need the distance from the outside of the brackets (the inside width of where the brackets mount), the length of the brackets, and the height from the side of the bracket and the center. If one of you happen to have a freak laying around and could get those measurements I would really appreciate it.
