Quinc
Buy a Superjet
- California
Blaster now has a 701ind rocker and transom wedge. Looking forward to riding down the face of a wave this weekend and not going over the handlebars..
Blaster now has a 701ind rocker and transom wedge. Looking forward to riding down the face of a wave this weekend and not going over the handlebars..![]()
is it backfireing any? May have sheared the key.
gonna say key sheared, your generating spark but at the wrong time so no ignition. Usually if the key sheared the back fire is coming from as the ports are closing it will finally ignite some of the remaining charge. Sounds like yours may be just past that point to where it evacuates all of the charge out before it can ignite.
Good luck. I hate stator issues (any electrical)
I wish they were still worth that. Cant seem to sell mine.Blaster B pipe chamber = Unicorn. $1,000.00 bill if and when you find one.
Why not go to the Solas 148?
hey mate i got a coffman rocket, water out of pissers is nearly too hot to touch, did you run into this issue at all? any way around it cheers
where do you get those rubber insert things that are circled in the picture?Yup replace those if you need too. I get new ones and drill them out so they fit a 10m bolt. The 10.9 grade bolts are zinc coated and not stainless. Also you need tighten everything up together at the same time and shim the case bolt. But biggest fix is running a hump coupler.
