Quinc
Buy a Superjet
- California
Blaster is finally done-ish. Just need to find some pink turf for the foot holds and handlebar pad.
Tiny tach. I use this:I was reading through this thread and I see you guys are posting speeds and RPMs and I hope this isn't a ridiculous question, but how do you know what RPMs you're running? Pretty sure my Blaster doesn't have a tac
@Quinc just read through all 11 pages of this as I bought a blaster today. Where did you mount the tach? Worth wiring up to the bars or just keep in the engine compartment?
57.4 MPH? I think your gaydar , I mean radar is malfunctioning
I brought back to life with the Quinc retro pipe repair guide. Two seasons trouble free so far.
THX Qunice.
coffmans last version of those pipe isolators were Teflon instead of rubber. I don't have any of those left. I have complete factory B mod and limited pipes that i'll sell for a bazillion dollars each, if you want to dump that coffmans system
Hey... I know this a really old topic, but I'm fighting major 701 vibration issues. It killed two stock pipe mounting brackets and also rattled the bolts all out on this same Coffman pipe. Apparently I have an early model of this pipe that has a simpler L shaped bracket at the front of the cylinder than later models. I can't quite see the shape of your forward bracket- although it looks like it doesn't tie into the head like the updated Coffman one apparently does- did you build your own? Also- did the coupler come from Coffman? thanks!It allows the exhaust to move a lot more, which I am not sure is a good thing. I will run her on the hose this weekend and see how well it works before I test it at the lake.
Damn dude! Glad I asked! Some great ideas! I do remember reading somewhere- maybe it was you- that said various (extra?) rubber mounts made it worse than if it were hard mounted. Did you also replace the rubber grommet insert things that go through the mounting plate on the pipe? (I've never heard of higher than grade 8 bolts BTW) When this problem first cropped up it sheareThe bracket you have is fine and the same as mine. You want to ebay search Hump coupler and get the 4 or the 5 ply. You are also going to need to trim it to the same length so it fits right.
Next replace the dampeners in the mount.
For hardware the best luck I have had is:
10.9 grade bolts
stainless nylon lock nuts
stainless lock washer
stainless star washer
stainless flat washer
Blue loctite.
Last couple rides with this combo and nothing gets loose or needs to be re torqued.
Lots of info here:
http://www.x-h2o.com/index.php?threads/coffmans-rocket-pipe-install-instructions.154627/
Are you still running the rocket pipe Quinc? If so, any idea what temp yours runs at? Mine is running around 170*..seems hot to me. Also where did you purchase the rubber dampeners between chamber and bracket?
