Freestyle McSuperfreak
junkyardj
┌∩┐(◣_◢)┌∩┐
congrats man!!
seems like this is the hull of choice these days, im realy looking forward to seeing what a true lightweight hull makes your motor feel like
McDog
Other Administrator
Staff member
South Florida
Finished deturfing with the harbor freight multimaster. I love that thing. Then I changed attachments and started hacking on the footholds. It worked awesome and fast. Best $30 I ever spent.
I took the plunge on the footholds. I outlined the footprint difference with the changes I have made so far with a black sharpy so you could see the difference. I'm tempted to go farther but I would prefer to maintain the recessed lip for the turf edge. I may cut it flush with the recessed edge and attach fiberglass to the inside instead of the outside to change the angle and give myself even more room. I may recess some sort of a toehold into the ankle area for surfstance too. I may even cut into the front left area under the front foothold into the bulkhead to give myself some more lateral leverage on my front foot too. I ride surfstance mostly so I figured I should give myself as much lateral leverage as possible.
Sanoman
AbouttoKrash
NE Tenn
The multi tool makes life a lot easier, especially removing turf.Pretty close to being rated the worst job to do on a ski.The only exception would be installing an exhaust chamber that is good and oily mixed with exhaust waste that won't fit!
You done " gone and done done it this time " . That is about how far I cut mine . I think I had about a 1/4 of an inch for the turf to recess . The bottom radius of the inside gunwale is what I was talking about leaving . Remember our conversation . You may need to add some material back to the bottom for support. I did on my stocker . Good Plunge to take . Worth the work .
McDog
Other Administrator
Staff member
South Florida
I've really gone and done it now....
It started with cutting out some more room for my front foot. Then I realized I could use some more vertical room in the footholds so I could use 25mm pad on the bottom and not have to shave it down for my feet. Then I realized there is a lot of foam in there and I would rather have polystyrene. Next thing you know I have ripped the whole tray out. Lots of work ahead. I hope this doesn't add too much weight to the ski to get the tray back together but with starting at 61 pounds I have a few pounds I can fudge without really noticing it. I plan to get this tray as close to perfect for me as possible. Then I'm more likely to keep this hull and not spend a buttload on a new badass superfreak.
Sanoman
AbouttoKrash
NE Tenn
Now you got a project, lol
That was the last freak with foam....
Josh,so none of the freaks have foam in them now?
The rok is the first ski l have owned without foam.Kind of freaks (sorry,no pun intended) me out not running any! Any advise on not worrying about sinking?
McDog
Other Administrator
Staff member
South Florida
It does get confusing. This is my main ride. I bought a WDK REV/Superjet project hull that will be my wife's new ski.
He's going the distance .... he's going for speed .
Since you are using poly in the tray are going to do a little reenforcement in the tray area / bond line. I don't think much weight would be added if you use carbon and use 2 pound foam in the top gunwale area . Calculate the area you will be reinforcing , pick a cloth weight and figure the same for the resin. That should help you make a decision . 1 pound of cloth = 1 pound of resin and so forth . Look at Spruce aircraft supply , They have a spray polystyrene kit . I have no info on it , but I will.
McDog
Other Administrator
Staff member
South Florida
I had planned to use 12 oz biax cloth for the foothold mods but I guess carbon would make sense now that the whole tray is involved.
I want polystyrene pieces so that water can drain out of any place it might leak in the future. The gunwhales will keep the foam in them and I will use 2 pound foam to shape the foothold areas that I cut out. I will put just a little 2 pound foam on top of the polystyrene to lock it all in and make the tray stick back into place when i'm done.
