- Jensen Beach, Fl
Should I install pump first and center up as best as possible for midshaft OR install midshaft first and then install pump... ???
I know either way I will need pump shims... Just trying to figure out that if I install pump first guessing eye wise that it will center up perfect with midshaft bolt alignments...
Also... I purchased 3M 5200 sealant to place on spacer for midshaft assembly... Seems like the best fit... water tight and permanent... this is what I want from the spacer... leak tight PERIOD... !!!
I have heard it can be done both ways...
Any suggestions... ???
