JetManiac's Midshaft Shop
JetManiac has new and used midshafts (aka: intermediate shaft), housings, couplers, and parts for your SuperJet or aftermarket hull build or rebuilds. Also for your Waveblaster and FX-1.
Send us your tired midshaft assembly for repair/replacement/rebuild OR select from our components and have one custom built to your spec. We have built hundreds of midshafts and know how to build them properly.
Otherwise we can provide you with all of the parts necessary to build or rebuild a midshaft assembly yourself.
Link to JM midshaft info thread:
http://www.x-h2o.com/index.php?thre...building-sn-vs-rn-etc.105232/#js-post-1212770
Midshaft rebuild kits
Midshaft rebuild kit - NSK $49.95 sale 45.90
(NSK sealed bearing, 3 grease seals, 2 bearing clips, 2 shaft orings)
Koyo Jap Oem brand Midshaft Build/Rebuild kit 75.90
(Koyo sealed Bearing, 3 grease seals, 2 bearing clips, 2 shaft orings)
Midshafts
SuperJet OEM Yamaha Midshaft (shaft only) $274.99 sale 238.95
SJ/B1 a/m midshaft only 129.
(same as the one formally sold by Cold Fusion)
SJ midshaft a/m (shaft only) $130. sale 119.89
(160mm overall length)
B1 midshaft new a/m (shaft only, uses wider B1 bearing) $135. sale 119.95
FX-1 midshaft new a/m (shaft only) $125. sale 109.85
(145mm overall length)
OEM Midshaft coupler thrust washer 7.99
(Installs between midshaft and coupler, 3mm thick)
Replacement midshaft Orings 2.49/ea
RRP coupler spacers kit 22./set
(1/2" midshaft coupler spacer, 1/2" engine coupler spacer)
Midshafts for OEM or shorter for custom builds:
GP1200/Raider 1100 OEM clean, used midshaft only 65.
(122mm overall length- splines at front of shaft)
GP760 new a/m midshaft shaft only 109.
(127mm overall length- splines in SJ/blaster location near rear of shaft)
GP800 (122mm overall length- splines in SJ/blaster location near rear of shaft)
VXR Pro 701 midshaft 221mm
Midshaft housings
Housings for '96-20 SuperJet RN/701, 94-95 SN701, 93-96 Blaster 1
New OEM Yamaha midshaft housing only $198. sale 168.
*without bearing and seals
New SBT 2.0 RN / Blaster midshaft housing only 129.89
New SBT 2.0 RN / Blaster midshaft housing 169.89
*With bearing and seals installed
New Lynx a/m Midshaft Housing only 119.
New Lynx a/m Midshaft Housing 159.
*with bearing and seals installed
Used clean freshwater OEM recon. midshaft housing 119. (limited availability)
SN midshaft housings 1990-1993
New SN SuperJet a/m '90-93 housing 119.
New SN SuperJet a/m '90-93 housing 159.
SuperJet SN '90-93 clean, Oem used housing 98. (when available)
OEM midshaft housing to hull bolt kit 8.95
(3 oem stainless clean, used bolts with captured lock and fender washers)
Couplers and Dampeners
ADA lightweight billet couplers
ADA billet lightweight Yamaha coupler set 84.95
Dampener for ADA couplers -Kawi style 24.90
or
Kawi OEM dampener $84.29 sale 78.75
(highly recommended for durability especially with larger motors)
ADA coupler midshaft side only 45.90
ADA coupler engine side only 45.90
ADA coupler for Kawi conversion 49.90
ADA coupler for Kawi 1100 conversion 49.90
RRP billet lightweight coupler set for Yamaha 89.95 (on backorder from RRP)
Dampener for RRP couplers -Kawi style 23.90
OEM Yamaha clean, used 3 finger coupler set 49.90
OEM Yamaha New 3 finger dampener(650/701) $90. sale 79.70
OEM Yamaha clean, used 3 finger dampener 19.90
OEM Yamaha clean, used/Bgrade 3 finger dampener 14.
OEM Yamaha clean, used 5 finger performance coupler set 59.80
OEM Yamaha clean, used 5 finger dampener 22.90
OEM midshaft coupler thrust washer 6.95
(Installs between midshaft and coupler)
Dampener for Thrust couplers OEM 69.90
Cold Fusion couplers and dampeners -discontinued
Coupler Covers and Parts
New OEM Yamaha coupler cover 31.95
(SuperJet 1990-2020 and WaveBlaster 1)
Custom coupler cover that does not attach to midshaft housing (clean, used, modified) 29.800
-fits better in a/m hulls that have a front foothold or reduced space in this area.
Coupler cover hat bushing -Yamaha OEM 7.99
Coupler cover hardware kit - 2 bushings and 2 bolts/washers 17.90
(2x coupler cover bushings and 2x stainless OEM hardware/washer)
Midshaft housing to coupler cover -rubber grommet piece 10.49
Midshaft housing to hull OEM bolt kit 8.95
(3 OEM ss clean, used bolts with captured lock and fender washers)
Midshaft housing to hull OEM Yamaha bolt 4.19/ea.
Midshaft Tools and Parts
Cold Fusion Driveline Alignment Tool 69.85
(for Yamaha 701/760 '96-20 RN SJ/B1/B2 Pump and Midshaft alignment)
PUSH Driveline Alignment Tool 65.85
SN SuperJet 90-93 Driveline Alignment Tool 65.85
3 finger Yamaha motor/midshaft OEM 650/701 Coupler install/removal tool 31.95
5 finger Yamaha motor/midshaft OEM 760/1100/1200 Coupler install/removal tool 31.95
Kawi sized coupler install/removal tool 49.95
(fits ADA, RRP, Epic, and OEM Kawasaki couplers)
Midshaft spline holding tool 39.85
(For holding midshaft while removing or installing Yamaha midshaft coupler)
JetManiac Midshaft build/rebuild service
JetManiac is the midshaft build and rebuild specialists, and we have built and rebuilt hundreds of midshafts.
We are perfectionists and it shows in our quality of work.
JM certified Midshaft Rebuild Disassemble/Rebuild labor 125.
JM certified New Midshaft Build Assembly labor 98.
Pro build upgrade with front and rear seals glued to housing +29.
*Front and rear seals are glued into a locked position with special rubber bonding glue and flash cured to help keep seals in position and prevent seal pop or movement, and to seal out water and corrosion.
New midshaft housing only build labor 40.
Midshafts
Midshaft housings
or
