E350
- Sacramento Delta
This seems like a helluva lot of work to mix two very soluble fluids.
It is easily the easiest thing I do on a jet ski …
Damn I would hate to be waiting on you to load up at the boat ramp then !It is easily the easiest thing I do on a jet ski …
I have to ask this ,or at least someone does , exactly how did running more oil make the water box blow up ?I would have never thought about it but it did cost be a waterbox on my SN. I put 4 gal in the empty tank then a pint of tcw3. Started it, let it warm up and blew the box revving it up. I looked at the tank and only the bottom half was blue. It had an extreme oil mix going into the engine. I became more interested in mixing after that.
Ever since I was a kid riding dirtbikes.......I've NEVER shaken up my 2 stroke mixed fuel. Put the gas in, ratio rite (or similar) the correct amount of 2 stroke oil, go ride. That's all I've EVER done! Just used my Stihl saw about a week ago......filled it with gas, poured in a capfull of 2 stroke oil, started it up and went to cutting.
The fuel air mix is normally too rich at the rev limit to blow a box. Quadrupling the oil in the gas makes it leaner. Ive had this ski since 1993 and that was the only time it ever after fired. My X2 will do it some when held against the rev limit but not very bad.I have to ask this ,or at least someone does , exactly how did running more oil make the water box blow up ?
BAH......I've never had a saw, or weed eater, or jet ski blow up on me. Just watch the fuel...THE INSTANT you put oil in that tank, the whole thing colors up and you're ready to rock! And you NEVER fire something up the very next second.....you drive to the launch, or pick up the saw and pull the cord a few times meanwhile sloshing (mixing) it all up.....................No WORRIES!!!That is chain saw abuse. Love you brother, but don't do it that way.
I would never hold a cold engine full throttle out of the water because of the high possibility of after fire and blowing the box. All my yamahas run 7000-7200 and their rev limiters are around 7400-7500. My stock big pin 750s are a little higher. Here is something very few understand, an engine takes much longer to get hot when it’s full throttle bouncing of the limiter. I can do much more thorough water clearing before it gets too hot. Most riders never clear enough water, that’s why most old engines are rust buckets.I am not sure I should continue but it's never stopped me before, you are holding the skis to the rev limit why exactly ?
.....MOST riders (my customers) never clear ANY water.......don't even know they're supposed to.Most riders never clear enough water, that’s why most old engines are rust buckets.
I mean getting all the water out of the exhaust and getting the head near boiling temp before I take the ski home. Over time most engines are ruined by putting them away wet.When you say clear water , do you mean starting the ski again after it is out of the lake to flush the water out? I always thought that it was to prevent hydrolock.
Getting slightly off topic here but I'll bite since I don't see this topic discussed in detail often...I mean getting all the water out of the exhaust and getting the head near boiling temp before I take the ski home. Over time most engines are ruined by putting them away wet.
