One thing when using Advents you MUST use 62T stator and flywheel. Sorry to bust you on this one as this statement is not true.
Alright guys I'm thinking about buying an MSD Enhancer, but I am reluctant to because of the reliability issues I keep hearing about. I know there are good ones and there are bad ones, but after talking to some people I found out that back in 2001 MSD changed manufacturing facilities or something like that and a bunch of bad enhancers were made. Since then MSD has had a bad reputation for their enhancers.
Just trying to get an idea of how many people have had good enhancers and how many have had bad enhancers.
Thanks:biggthumpup:
I've had mine for 3 years and haven't had a problem with it. It is, however, going to be replaced this winter with a T/L system. :Banane01:
about how much do Wax Racing CDIs cost?!
i've personally owned 3 and i think one went bad on me a long time ago. i had the problem where you would hit the start button and it would crank over and over but it wouldn't spark until you let go then it sounded like it wanted to fire just as you let off the green button.
stock cdi's go bad too.. so.. whats the difference, right?
I had this same problem and thought it was Enhancer, turns out the start stop switch contacts needed cleaned. Figured that out after flywheel was off timing checked and put back together, then e- box disected and inspected then put back together all to finally realize it was s/s switch all along.
(still got that bad Enhancer?):sneaky:
I noticed a huge difference between modded stock CDI w/ stock flywheel and Riva lightened flywheel w/ MSD Enhancer, not sure which one was majority of improvement though.
How much you want for the Enhancer Glenn?
I know that Greg (Advent) has had his problems with the Advents CDI boxes but I've been getting good ones for a year or so, And he does warranty them if you have problems...
your correct they are about $600 US about $800 AUD i contacted wax racing about it but its way to much for me right now :frown:I would love to try Wax's CDI but I think they are still $600.00 (correct me if I am wrong Jared) He is working on getting them for less though.
