Trying to get my ski set up as a full limited but like stock reliable rec boat. Lots of bolt on mods. Trying to get it to work perfect, like stock, just a lot more power everywhere.
Stock motor, Ada girlded head 180 psi, fpp manifold kawi fpp head a-pipe head pipe sj limited chamber, stock water box, dual 38 with reed stuffer carbon dual reeds, #0 lighten flywheel, msd ignition, 10/18 prop, aggressive scoop intake, works dominator ride plate, hard line tach.
Carb set up is dual 38mm stocker rear fuel pump front slave. Stock pop at 53, jetting 135/75, back top screw out about 1 turn more than front.
Pipe is damaged so bottom screw is wide open, middle and top are completely closed, lots of water in the pipe. Jetworks blue valve one turn in.
Dual cooling to manifold, no restrictors.
Ski runs real good. Will hesitate if I cruise around at 1/4 throttle for a while but I think it's just loading up with water. Good throttle response everywhere unless like I said I let it load up but were talking about 20-30 seconds and a lot of water goes into the pipe. I tried 137.5/75 jetting and the ski ran like
My big problem ATM is that the ski dies on my after 20-30 seconds wot. Just plain shuts off, start right back up with great throttle. Pretty sure it's not my petcock, lines or vent.
A number of people say my setup should be perfect and others disagree. One person claims my ski won't run right with 53 popoff, drop it to about 20, but can't give me jetting specs. Others say 53 should be fine.
Some say fuel pump is fine, others say I need to run fuel pumps on both carbs. Can I just get the one missing plate and add it to my front carb?
I don't want to damage my motor. Carbs testing out right. Anyway, I would just like some more opinions because I have only gotten a hand full. I'm not tweaking this thing out for full race craziness. Just a powerful surf/race/flatwater boat.
Oh, pretty smooth idle at 1200 rpm, peak rpm is 7100rpm give or take and rev limiter set to 8000. The dying issues happens around 7000-7100.
I think the hesitation at 3000 is because of too much water in the pipe, clears out immediately and doesn't come back. Now I'm just rambling. Ill see if I have a decent video to post up tomorrow.
