- amarillo ,tx
I just ordered royal blue molded diamond
Sent from my QMV7A using Tapatalk
clarified! thank you.
Alex taper bored my carbs. #PFMgarage!!
@speedysprocket thanks!
Went out for some testing and wanted to take my new go pro session out for a spin.
I used a small drill bit then a self tapping screw to grab them, used a pair of angled(bent) needle nose pliers while the carbs were in a vise to leverage them out. Look back in my build I covered that
@Erik Villeneuve
I did another, although this carter B ride plate was harder to do with the hump it has in it.. I used a piece of paper to mark the distance from the one side to the other. Folded paper in half and got the middle. Then used a protractor to start the 6" circle but had to use my imagination for the one part.
