I pulled this off of the Group K site... "A Skat Trak variable pitch stainless steel impeller will be a mandatory modification for all Group K 750 kits. We recommend a 9'-17' pitch for the 750 SX, and a 12-20 custom for the Xi & SS (SX engines fitted with a lightweight flywheel will require a 10'-18')." & "The stock rev limiter on all early 750's is set at about 7200 rpm. The stock "big pin" 750 ignition's limiter comes in at about 8000 rpm."
I have only tried a 750 Kawi once and found that it was more race oriented than freeride capable. That said, to me, I would opt for a low pitch swirl on the 750 to drop off some top end and build better holeshot. If your ski has the higher rev limit then the lower pitch swirl design would def be the way to go in my opinion. You should get much better holeshot and most likely will not be bouncing off the limiter unless you get unhooked. Save the 10/18 for the lower rev limit if that is the case. I had a 10/18 Skat on my old 650sx and loved it. Great all around performance with a very noticeable increase in holeshot response. This was of course going from the stock aluminum impeller though. These are your stock 750 impeller pitches, it appears they are all aluminum. Only the SXR had stainless it seems, and if I recall, it was a 13/18 swirl design.
750 Sxi Pro
98-02
9/17
750 SXi
95-96
9/17
750 SX
92-95
14/19
