SX/SXi/SXi Pro My first build/first stand up
I believe it was 90 bucks to have them done also break the edges on the intake and exhaust ports.
I also believe that i found the problem with the over heating. I am pretty sure it was due to one of the exhaust gaskets. I was waiting for about two weeks for them to then find out they where on back order!! :aargh4: So i just made my own but didn't realize that one of them needs to be solid to redirect the flow of the water cooling the motor. I ordered the right gaskets from somewhere else and they should be here today. So now hopefully with the right gaskets she will be ready to rip.
Has anyone used one of these bilge pump mounts and if so do you have any pictures of how it goes?? I am a little confused on how it all mounts up
looking at the picture the lower side of the mount will bolt on using the twp lower bolts of the driveshaft bearing support on the lower dash behind the e box. The bilge pump will then bolt onto the flat section with four holes, the area in the top left of the pic.
I also agree with 97superjet, I have always just epoxied mine directly to the hull, the brackets have a tendency to break the blue basket section of the pump housing.
