WAB
salty nuts
- coastal GA
What if you knock the nose off and need to get towed?? You are pretty much F'ed. For that reason, I put a Stainless tow hook on the underside of the hull the last time I had to pull the gas tank out. Works great and was less than $10. It actually helps keep the nose up more when being towed also.
Somebody coughIdokcough has broken one of those expensive aircraft front loops when towing somebody in at 40mph.
:biggrin:
