Ok guys, as the title says this is my MOMS tigershark 640 montego 1994. I bought it for her. Runs perfect, its in mint condition everywhere. One huge problem. Its a FLOATING"" driveshaft assembly. Which means if the alignment isn't perfect your screwed. Anyway I reved it up on shore and the driveshaft is vibrating big time. It is so bad the ski will cavitate and not move. The driveshaft begins to split and wobble like an inch out after 1/4 throttle. The old coupler dampener was ripped so I tried a new one. Same thing. I though the driveshaft was bent, so I pulled it and put it on a machinist stone table to check if it was flat and not bent, after several observations I concluded it is most definetly not bent. I'd think its the engine alignment. How do I alighn this sucker?
