- alberta, canada
So I figure its about time to start this build thread. I bought this hull off of Steve at Trendsetters mid winter for a winter project for me and my wife. Hull seems to go together easy as pie minus the waterbox fitment. I was working in china when my wife started on it . Here are the goodies:
2011 - WDK Rok-R hull white gel coat
61x/62t shortblock (for now)
monkey grip motor mounts
ada lightweight couplers
cold fusion midshaft
stock 38mm carbs
limited b-pipe
x-metal water box
cast RRP pole
epic ignition
lightened stock flywheel
jss coil
ada head
stock 144 yama pump
skat-trak magnum c+75 12/17 swirl impeller
some other goodies.
begin such a different hull I wanted to start with a fairly tame motor to really feel what the hull is capable of. Ideally I would like a 771 but if it turns out to be a blast maybe will move to a 950
The Rokr fresh from paint (black with a turquise sparkle in clear coat)
some weights
while I was working in china Lauren turfed er up
stock 38mm carbs
limited b-pipe
x-metal water box
cast RRP pole
epic ignition
jss coil
ada head
stock 144 yama pump
some other goodies.
some weights
