ncbrock's Gulf Tribute stunt hull kit assembly
McDog
Other Administrator
Staff member
South Florida
More pictures.
Waternut
Customizing addict
Macon, GA
mmmm.... Look at that sexy devil puttin the hood back on!
I agree on the leaping thing. When I rode my 750 and SJ (which had the same pump, engine, etc. in it), I would always approach the wake with some speed to get more air. With this ski, you just slowly approach the wake, give it the beans, and you go so much higher. My normal ski was a flatdeck last year and the wide stance does take some getting used to. You're more stable but you initially overcompensate your weight in turns. Since my last ski was so wide normally, going to the stunt wasn't much of a change for me but I do think it will take a little time for most people.
Waternut
Customizing addict
Macon, GA
LOL That's what I was afraid of. There isn't a lot of dust in the air over water compared to roads and dirt so air filtration is less of an issue in boats but fire is a more serious issue. The purpose of the flame arrestor is to extinguish the flame and prevent the spread of fire in the event of a backfire. The paper or cotton air filter would actually assist the flame in spreading.
Waternut
Customizing addict
Macon, GA
The holes being too close to the edge is most likely the least of your concerns. When Dan drilled my battery box plate, the holes didn't line up with the battery box...not even close. Pretty sweet huh?
Sanoman
AbouttoKrash
NE Tenn
Hood came in today. It and the liner frame will need some trimming and some breather holes. I know Dan usually attaches tubes to the holes and leaves it open but is seems easier to lay some fiberglass across the open area to close the hood liner and put some breather tubes down like normal.
The forth pic of the side of the hood.l have the same crack in the same place??? That is Highroller consistency and quality!!!
McDog
Other Administrator
Staff member
South Florida
is that big hunk of metal with all the parts layed out the battery box plate? seems to be a lot of extra metal on there and the threads seem pretty close to the edge
I checked it and the holes actually do line up. It is a heavy mo fo though.
McDog
Other Administrator
Staff member
South Florida
I see a LOT of body work in your future if you want it to look nice, but we all knew that up front. Everything does seem solid though. Waternut got his looking nice amazingly fast and I'm sure he can give you some great advice on the bodywork.
I suck at it myself. I can't even spackle a wall right. I know I lay it too thick and sand too much, but I can't seem to get right no matter what I do. I can paint fine but have to pay someone to mud/spackle for me.
Sanoman
AbouttoKrash
NE Tenn
Yea,we all knew the stunt would need some TLC.But you can polish a turd.............
why wouldnt the battery box just come with 4 seperate inserts? wouldnt that cut weight a lot, or would it not be strong enough? Im not sure how well i can polish turds, it will be my first time doing anything.
YAY BODY WORK!:rant:
McDog
Other Administrator
Staff member
South Florida
It would be plenty strong enough but 4 holes in one plate was easier I'm sure. You could even epoxy the battery box straight to the hull with no inserts.
Waternut
Customizing addict
Macon, GA
Both true points. I chopped the excess ends off of my plate and just glassed it to the hull. If you really want to be anal you could cut the plate into 4 small squares and glass them individually to save weight but I don't think you'll save enough to make it worth the effort.
Body work is cake if you have the right tools but an arthritic nightmare if you don't. Best of luck to you... In fact, the body work was the easiest part for me.
I have some assorted hand sanders and whatnot but no air tools. no bondo\filler experience. this whole build is an experience actually. I got time during the week though, school is nearing the end I have no work to do so as long as its light outside its work time.
Sanoman
AbouttoKrash
NE Tenn
Hand tools will work fine.You don't really need to have a bunch of air tools to do well. Plastic filler is somewhat like drywall thinner coats means less sanding.Grezsky on the forum knows how to prep and paint one.You ought to pm him.l think he would give some good advise.
customride0105
sterling va
i actually didnt use any body filler on my hull... did everything by hand easyest way to get something stright is by hand you can get it close with a sander...
i spent a full day working on my hoods. just preping them for paint. i had cracks.. theres something in the middle dont konw what that was and actually if you look down the hood.. the lines arent stright on the one side the curve in at the end i think on the rt side of the hood where it meets the ft of the hull... yeah i noticed that lol..
great product called fiberall. its got strands of fiberglass in it just like tiger hair but sands smooth like topcoat. and is strong as crap. for the hood i actually sealed the hood like mcdog did and the ft where the 2 peices meet at that looks ugly asshell. i filled that in with some t211. and went over that with some fiberall.
i didnt use any thing on the hull witch i should have but id be still wroking on it.. first sanded the gel coat down. primed the crap out of it blocked that and was done and you can seen how mine turned out..
Waternut
Customizing addict
Macon, GA
Not sure how you got away with not using any filler. Can't sand something smooth that isn't there. I has some large holes that needed to be filled with a form of bondo hair and then a lot of other stuff where there were little holes or sharp edges had to be filled as well. Sanding only removes high spots.
I noticed the hood isn't perfectly straight as well. Nothing but the best ya know... Now look down the sides of the top deck. You should see a nice crease where the tray starts on the left side. I didn't notice this until I had already painted it.
