Freestyle Need help setting up total loss
hi I have a dasa 863cc 8mm stroker motor with power valves and trying to setup my msd total loss up for flat water freestyle can anyone help. I need it to be competitive thanks chase.
usa
32* static for long rod crank
start retard 5000
max rev limit 9000
max speed retard 24*
max timing all on
max retard +15 on
elec start on
start retard on
all others off
usa
what 2 stroke in a ski runs at 9000 pump loaded?
on the msd graft, yes
this allows for over rev on high compression setups
Christian_83
Xscream
Denmark
Isnt the max speed retard, the timing at the end og the rev limit? Ex 24deg max speed retard.
Then the Ignition Will be at 24deg at 9000rpm?
No. All the timing setting are relative to the actual timing your pickups are seeing from the flywheel. Your pickups may be set to 32 degrees. You can then retard up to 8 degrees from that for your base timing, so as low as 24 degrees in my example. Max retard is additional timing taken out as RPMs increase. So Dartman starts at 32. He is subtracting 24 degrees, so his advance at 9000 RPM is 8 degrees.
usa
that is correct...
i don't think you can go -8 from base timing
-7 is most you can retard for static
