- CT
my ski ran mint the past 2 days. then at the end of the day it hesitated once and at wot it just cut out.it fired right back up and ran fine but then would occasionally do the same thing at wot, just stop dead. but it fired back up everytime first try. the next day i checked my check valve, went through the carb, checked fuel filter, changed plugs, checked stator readings (which were all good), checked spark plug coil readings (good). it idles fine, revs up and down perfect on the trailer and idles around great in the water. but when i give it any throttle it dies now. it boggs then dies and when it dies it dies quickly like i puleed the lanyard. it takes a little longer to start back up now but it always starts again. what could it be?
