freestylegeek
waiting...
- Grand Rapids, MI
OK, I thought I had my air leak problem taken care of (I didn't JB weld my second pulse line fitting into my cases :banghead
. But, when I rode yesterday, it often acted like it was still there. Case in point: I did a big bronco (nose stab) and sunk it in pretty deep. I came back up, and obviously, the engine was starved for air. Well, even after the hood finished draining, it still felt like it was starving for air. It was basically running on one cylinder. If I kept on the gas long enough, it would rev to a point where they both would kick in, and pull my arms off. But, as soon as I let off the throttle, back to one cylinder. It would do this for about 30-45 seconds, then it would be running fine.
Now, annother thing that concerns me is that when I try backflips, and land upside down, it revs to high heaven (air leak). Then, when I roll it over and load the motor, it dies. Then, it takes about 30-45 seconds before it will start again.
Also, when it's on the trailer, it will idle fine, but when I brap it, it doesn't really rev back down. Every time it does that, I can hit the kill switch and it dies. That's what makes me wonder if it's an air leak or not?!?! If it was an air leak, the kill switch shouldn't really kill it. That's what it was doing when I had the air leak in the pulse line fitting - I ALWAYS had to kill it by pulling the throttle. After I sealed that fitting up, I did a leakdown test, and basically passed (just barely over 1 psi/minute - about 50 seconds to go from 2 psi - 1 psi)
I'm dissecting my carbs now, and seeing if there's anything suspicious in the internal filter, or in the circuit somewhere. Anyone have any ideas where else I should look? When it's working right, this thing is a monster! I'm hitting rolls just off of idle :barrel:. Toss out some ideas people!
