New 750 x2 build
Got the inside painted and started bolting everything back in
Took a time out today on the ski, sold a seadoo speedster and bought my new carry
Taurus poly judge 45/410
Big holes are one slug round, small holes is one buckshot round. Shot from 30ft
Well I managed to get a little done today.
Got the bilge outlet test fitted
Got my new pissers test fitted
Got the bilge switch test fitted
Test fitting the start/stop switch
Working on the freestyle trim and throttle handles
For a few more things done today
Got the ride plate d cut
Got it mounted
Pulled the motor from the zxi
Installed the oil pump block off
Removed the chokes and installed primer kit
Set the motor in the hull to start test fitting and hooking everything up
You guyz seem to know your poop. I have a blaster that the owner before me just sprayed it with crap spray paint. I live in South Africa so there are know proper places that I can take it to be sprayed. Do I need to Do a gell cout on the bottom or can I just spray it like the top.
Thanks
stagesrt4
see ya out there
St Charles IL
that bile fitting location might have been a bad spot
If your gonna be running the dual CDK IIs then they might interfere with the each other
Got a lot done today, I got the water box drilled, 3 1/2" holes through both baffles
And mounted
Got the fuel tank filler and pickup modded and installed
Working on free style trim, mostly done
Installing the carbs and fuel lines and cable
Another late night update
Got the wiring all done and deleted anything extra
And got the free style trim done other than clamping the cable and adjusting it a little
Ducky
Back in the game!
Charlotte, NC
I would put the start stop switch back in the stock position on the left side of the handlebars. It will give you added stability for open water starts.
Argo, Al
Man! You sure are moving fast! I just pulled a ZXI motor for my X2 the other night. Did you pull the e box out and say omg that thing is massive? Have you tried to put the spark arrestor box on the carbs yet? Just wondering how it will fit. I'm thinking it will hit the hull a little bit.
