tntsuperjet
- Georgetown ca
Just to clear the water.
I will not send a pipe to anyone to test that is just a rider slash self mechanic.
There are to many things that need to be tuned tested and known to just bolt on a proto and exp results.
Even couple good tuners had trouble with original setup.
I can't send a pipe to anyone I don't have first hand exp with and trust there feed back. Way to many variables.
If you want to be considered for test subject here is criteria.
1- be able to bring you and your ski to my shop.
2- be able to install the pipe yourself.
3- be able to go to lake with me day after day to test different setups.
4- be a accomplished engine builder, examples, dasa, judge, chapin or in there caliber of tuning.
5- be willing to test and tune to the extreme of possible engine failure.
But if you are not of one the above listed, your option is to buy pipe and do your own testing.
There has been one of those guys post on here about the pipe he purchased and did his own setup and had good results.
But I can't just have random people test pipes.
One they cost me about 800.00 in labor to build and there money losers until production stream lining takes place.
When I say cost me 800.00 that means I can generate 800+ in shop labor doing other jobs in same time frame as build a pipe.
Your looking at 14-20hrs labor for one proto type pipe.
So if you want to spend 1,000 for a mild steel test pipe I be happy to build send you one.
Other wise sit back relax and read about those in my network who are working with me to develop the new pipes.
