New Impros Hooker Impeller for Yamaha
u think a hooker would be better on my limited sj than my 13/17 set back concord? are these props for all low end, or do they have some midrange?
Shrivel
Requires therapy.
Acworth, GA
I noticed no decrease in middle and top end over the Skat 11/19 I replaced - if anything, it was better all around.
It was well worth it for me. Now, if I could fix my carb/fuel issues, I could really tell ya how much better it is...
Officer Mike
TJ / SJ / JJ
Harveys Lake
they are designed to be better all around.no matter where or when in the rpm range or load combination they are designed to stay hooked for maximum efficeincy..
wademcgee
Middle aged toy maker!!!
I'm no expert and just getting my water legs back, but I have to tell you this prop blows away anything I've ever used. I had a Solas 14.5/18...came with the ski. I've ridden a lot of skis as well. I'm a flatwater/freestyle kinda guy at about 200lbs...give or take a
Big Mac. The prop transformed the ski. Got all the normal goodies, not stock. I would venture to say I actually gained some top end. It keeps pulling. I've hung on to about 54 mph or so in chop but haven't had a chance for any clean water runs. Highly recommended to all.
wademcgee
Hey man, you are preaching to the choir. I thought a used ski was just used...not used UP!!! J/K, but seriously I have virtually replaced every used part on this baby. Good thing it came from a good dude... The hull is solid as heck, but everything in it has internally combusted! Can't be too far from the end though, there are no parts left to replace!!!
GIL
Power In The Hands Of Few
Cullman AL
OK-the new Hooker prop is a 75mm hub, are you guys running a TBM or R&D afterburner pump cone in conjunction with your Hooker prop? If not-
what bore exit nozzle and what pump cone are u running???
So Cal
Thank you all for posting your responses. I'm so glad to hear you are as happy with the Hooker impeller as I am.
Please don't hesitate to contact me with any questions or concerns.
By the way, these can easily be machined to fit any C-75 magnum pump that is 140mm, or made to fit a larger Magnum pump as well (146mm).
Have a great weekend!
David
GIL
Cullman AL
not to get too far off topic hear, but, F!@# a dam TBM pump cone. I have been running a TBM cone setup w/the shortest cone, along w/a C75
Legdrag Mag 12/17 prop and a 85mm exit nozzle w/Virgin Trim ever since I had my Lamey installed. I have F'ed w/my Lamey set up for neary 4 F'ing months now-took TBM out and guess what-the F'ing Lamey is F'ing awesome!!! Moral of the story is-if u run a 75mm hub prop-don't run a TBM or a R&D afterburner. Use your new prop w/a Wet Wolf stubby cone and a 85mm exit nozzle and rip it up!!!
