It was the wear ring. I ordered the SBT replasment from Jetmanic and it works great.
Im having a similar issue. Drive shaft locks up when prop is fully tightened. I have tried with and with out washers behind prop and same result. Anyone else have this problem?
Sent from my MB860 using Tapatalk 2
Can anyone help me with this one? ^^The prop is a solas yb-sc-k 15-19. The ski is 96 wb1 stock pump. The solas prop chart says it will fit the ski.
TopCan anyone help me with this one? ^^
the spacer or washer isnt large enough then. you are bottoming out on the statorYes it spins freely inside the wear ring, locks up when it bottoms out on shaft.
Can you see a gap between the stator and prop? Are you using the right washers?I tried it with 2 washers behind prop and it still would not spin.
Still have the rubber on them? If they do try prying the rubber off one and using it.I used the factory washers/spacers.
