Here the infos from WakeUp race performance:
RICKTER X-FS
The latest development out of the Rickter serial: The new X-FS.
Finally this is the back flip specialized Jetski from Rick Roy. It is very short, very light, with an 8 " set back and enlarged pump area in order to keep the water flow powerfull as long as possible during set up of a back flip.
This hull really helps you a lot performing you 1st back flip and if you just are able to do 1, it will help you to master 2 or 3 or more. As this hull is very specialized it is the wrong hull for old school tricks or free riding.
STAGE I - Hull only
Comes complete with hood, pole bracket, mat set and adjustable foot holds. 100% compatible with Yamaha technique.
US$ 6.500,- in Fiber VOB Bangkok or € 5.825,- excl. VAT VOB Austria
US$ 9.500,- in Carbon VOB Bangkok or € 8.290,- excl. VAT VOB Austria
US$ 10.800,- in Carbon / Kevlar VOB Bangkok or € 9.290,- excl. VAT VOB Austria
STAGE II - Complete engine, ready to build in.
8 mm or 12 mm stroker engine with billet power valve cylinder & ported crankcase, incl. carbs, manifold, reeds, flywheel, dry-pipe.€ 9.350,-(8 mm) excl. VAT VOB Austria
€13.990,-(12mm) excl. VAT VOB Austria
STAGE III
Equipped with 950 ccm, or 1000 ccm stroker engine, Billet power valve cylinder, billet crank case, adjustable Rick Roy handle pole, steering and bar, Magnum Pump, Power Factor pipe, freestyle fuel cell, etc Depending on compression and ignition up to 220 HP The Bun 1000 ccm engine is used by the 2008 Freestyle World champion Fumikazu Watanabe and the Amateur World champion 2009, Manabu Matsubayashi.
€ 29.200,- (8mm), 33.400,-(12mm) excl. VAT in Fiber VOB Austria
€ 31.700,- (8mm), 35.900,-(12mm) excl. VAT in Carbon VOB Austria
€ 32.700,- (8mm), 36.900,-(12mm) excl. VAT in Carbon / Kevlar VOB Austria
