- Lake McQueeney, TX
Thats an interesting discovery how you cant turn the bars the whole way witht he minus 4 turnplate, hw much through do you get? would you be able to take a pic of the nozzle when the bars are cranked fully to the right? Would there be an easy fix for this problem?
Could you angle your throtle down and mount it to the fight more (closer to the grips) would you get a full turn that way? does it hit anything when the bars are cranked so u would be turning to the right?
Cheers
All I have to do is cut out a small space on the pad to allow clearance for the throttle cable. I tried moving the throttle around but it hits no matter where it is mounted. It almost goes all the way. Only like 1/4 inch or so till the plate hits the steering stop. When I turn it to the right, the start/stop switch barely touches the pad, but the plate turns all the way to the stop. I wonder if the WDK pad would take care of the problem? http://www.waterdawgkustomz.com/proddetail.php?prod=WKSJ-CP
