I started a tread on here asking for recommendations on mechanics in Northern LA and Ventura County. I live in Ventura. The only two mechanics anyone mentioned were Art and Greg. I spoke to Art at length and often. He is very apprehensive about me bringing in my ski to him with the parts because he has had bad experiences with used stuff that people bring in. I've called at least 6 other shops and no one wants anything to do with a TL ski. Hard to believe that in all of SoCal there are only two people that can work on a TL ski. You mentioned you would go to several others before Greg. Who and where are they?
Art recommended the 04 or later SXR ignition. I have a "wanted" post on here and two other forums that I posted 3 weeks ago for a complete SRX ignition and not one reply. I've looked on EBay as well. Nothing.
Sent from my iPad using Tapatalk
You do not need to take your entire ski anywhere. There is nothing magical about a ski with a total loss system. I could understand someone not wanting to try and make it work, but to remove and replace the components is not difficult at all. It would be REALLY easy to unbolt your stator and ebox and send them to John at Jetski Solutions-- he specializes in cleaning up electronics. All you would have to do when you got it back is bolt the two back on, plug in the wiring harnesses and go-- it doesn't get much easier. Get a better CDI, post a WTB ad on PWC Today (more kawi stuff there), put all your poop in a box and tell him you need a stator and ebox that will work together. I know I have mentioned this-- but his coil wire upgrade is absolutely worth it. You cannot go wrong sending your stuff to him.
The 04+ CDI box is ok, though I have heard they burn out more than the pre '04 because of the level of voltage going through the tiny pin harness that kawi used. I hardly ever see a bad pre '04 CDIs unless someone jumped their battery terminals or something.
I have a CDI out of a '95 ZXi that will work with your ski as well-- #3739. PM me if you want it.
I do pretty much everything myself except machine work, but in the rare occasion I do have other things done, I don't limit myself to local shops.
If I were to have a motor ported, Tim at Z-Force Racing would be my pick. Dude has built and tested tons and tons of race boats and really knows his stuff.
Art at Jetworks is very good, but I have taken my ski there a few times to have it tuned at it still ran poorly when I got it back. I have since learned to tune them myself.
Vey's Motorsports is good-- he ported a cylinder for me a few years ago before I knew Tim at Z-Force. Vey is in San Diego and his shop does good work
Chris Newmiller of Newmiller Machine in OR does all of my machine work-- no one pays closer attention to the details and getting stuff right.
There is also TBM, Kommander Ind who are both known for doing good work.
Greg mostly works on rec boats these days. I suppose he would be ok for what you want done, but definitely not my first choice. The copper in the plug wires in that old ass stock coil you have are probably practically dust right now-- those suckers need to come out, and John at JSS does a great job with them.
