SkiDiggity
formerly kawirider142
Ski looks good!!! the sizzler makes good power, well it did on my friends 650. you should look into getting a prop for sure to get the full potential out of your set up.
Want to redo my turf
I'm looking at the same theme again
Or what else you guys suggest will look good on my ski?
Should I do the top of the gunnels aswell?
Any success with the 3m backed turf? Does it hold well
definitely do the tops if you are doing turf, and put in some foot holds at the same time if you don't have any yet.
only reason i dont want to do the top is i love the soft factory cushion that's on there saves my elbows a lot my last ski had on top and hated it but i love the look
i got blowsion foot holds i believe
I have one RN SJ with the gunnels not turfed. I like that the factory rubber caps are very grippy, but not as soft as turf.
Nice ski, i have an 09 also, and love it
have you modded for quick steer?
Sounds right, but the steering cable that you have now won't work. You need to buy a pre 08 cable.
If your doing freestyle I think it would have been a bit better with the nozzle angled up. The nose up kinda helps out for the slower sharp turns. Just an opinion i guess. But you also said you ride everything so i cant vouch for racing and surf. Rockered nose looks good. Turf the rails when you redo the turf.
