Super Jet newb from Africa
Poizen
Mical
South Africa
another order placed with the number 1 supplier on the X Jetmaniac
cold fusion red mounts
dual 38 carb base gasket
carb manifold to motor gasket
mikuni oem carb rebuild kits
b-pipe manifold to motor gasket
b-pipe manifold to headpipe gasket
Mikuni oem 1.5 needle and seats
Mikuni pop off tester
Oregon
If you're moving to the UK check out ATP's products. I picked up their new billet lightweight pole and steering for my new WCF Vision. I have only seen pictures so far, but the hull ships to me on Monday so I'm very excited. I bought the ATP because it was lighter and cheaper than the RRP's. Here is ATP's website: http://www.airtimeproducts.co.uk/index.php Here's the best pic I have so far. I'll start a build thread next week hopefully.
Poizen
Mical
South Africa
since the maniac shipped my parts same day means they will be here soon so i started prepping
found that i have 2 and a half broken mounts glad i found this else things could of got nasty
im thinking of removing the stock rubber under the motor as its digging a hole to china
other pics
atleast i can clean my engine bay now
Poizen
Mical
South Africa
v-force 2 reeds ordered
serioulsy guys do not i repeat do not talk to chris/jetmaniac he throws sweet deals towards you and steels all your money lol ah what a great parts supplier i have a real pied piper
cant wait to have this all together
Poizen
Mical
South Africa
well 1of 2parcells from the maniac
And got busy putting it all back again all I need now is the reeds and I can ride again
Poizen
Mical
South Africa
Pole fitted
Ran into problem with the 09 steering cable
The atp pole cable mount is 30mm further back so I need to make a extender nut
But for this weekend I made a plan so I can ride
Poizen
Mical
South Africa
decided to build my own cats trim system as its super easy with 08+ hulls as they have all the items needed
will take pics as soon as i install it on monday
the cable i had custom made 8mm OD Teflon lined with 2mm stainless core cable with all stainless fittings
made a custom stainless bracket to hold the cable and on the back side a adjusting screw to controll the nozzle drop for starts and keep the load off the cable in rest position
will post vids and pics soon
964Chris
FREEdumb obtained
TEXAS
sounds like a hefty trim cable. Good stuff. keep up the good work.
