Ducky
Back in the game!
- Charlotte, NC
Looks awesome Head Honcho! Cant wait for your to ride it!
Are you sure the hull is a superfreak? They all slide way to much. Never herd anyone say they don't slide enough.. I wonder if it could it be in the pole length? So many SF's out there maybe someone will let you barrow a ride plate to try before you chop yours all up.The rear would not break loose
The mount looks fine. The carbon holding it down not so much.First failure. UFO mount failed.![]()
Sent from my SAMSUNG-SM-G930A using Tapatalk
the gflex should deff do the job. I do like the aluminium style inserts though.
I got a tip from the guys at Xscream to glue in parts. West Systems 404 mixed (high desinty) in the epoxy and you will have glue as strong as russion vodka. Its crazy how big a difference it makes. Just a bit of normal epoxy in the bottom of your plastic mixing cup (its some strong, but also brittle), vs the same epoxy mixed with 404 in the plastic cup (now its crazy strong and not brittle)
Shush it Askhole.............Hey BK! Where did you hear this before?? Lol
Well there ya goGFlex. I believe it was my fault. Had sprayed some paint in that area where it was all nasty looking from where a different mount had been for a Powerfactor. Forgot to re-scuff it.
Well, Finally started back working on here. Took a nice long break. Insert glued back in. But have a trim cable issue, so got to pull it and send it back to Maniac. But needed to pull pump anyhow to seal up a one or two dozen small leaks in the hull..................
