- Trumbull CT
Which is better for freestyle?
Dasa 10 mil stroker.. PFP.. 148 mag.. etc etc..
Indecision as to which carbs to order.
cool ,but if i run one of each, what kind of oil would i need to run with these ???
Nice !!!!Duh! Honda Oil along with blue Honda wax!!!
The onces you get cheapest. I just bought a set of brand new 49mm Full Specs, that i swichted from a dual 48mm Riva power bomb setup. Both carbs are with bomb sight. Nobody have been able to tell me what the main diffrence i these carbs are.
So i took some pictures when i were to do som re jetting.
I will say 9 out 10 guys, wouldnt tell the diffrence from the Riva's to the Full Specs (in same engine, with same jetting)
I cant compare with BJ, as i havent run a set of thoese buuut im pretty sure they are "the same" as other annular discharge carbs, ATP, Green racing or what they were named.
If you look carefully at the bomb site, you can see how Ed ports them to maximize air flow. Also, Ed will smooth out the throttle shafts for the same reason. Their is also some differences in the throat of the carb . At the end of the assembly, all the FS are flow bench tested for optimum performance.Waterfreak, sorry if i may sound ignorant, but what small details of FS??
I took some pictures side by side, when i opened the carbs. no really diffrence.
Matt, just my point. But i find it really hard to feel "any" noticable diffrence in these "some years old" Riva vs brand spanking new 49 Full specs. And in now way any diffrence that would justify the price diffrence.
