- sunbury ,ohio
I highly suggest a larger ''funnel'' .. An Upside down ''VP jug'' would be about right size
to keep everybody accurate , but your trailer is really a nice set up . carry on !
Any updates?
I highly suggest a larger ''funnel'' .. An Upside down ''VP jug'' would be about right sizeto keep everybody accurate , but your trailer is really a nice set up . carry on !
Just FYI , in my trailer I used the plain white foam in 1x4 ft pieces x 1'' '' cut to fit tightly ,then topped it with 1/4 plywood , and 1x3'' firing strips to cover the plywood seams , it does not even get hot in the summer sun very comfortable ! As far as the spray on foam as in the pic above ,Im sure its even better !! But I was just letting you know the 1'' foam is VERY comfortable and does the job nicely in my case !What kind of foam did you use? I have a cargo trailer we use for camping and i was planning on pink foam someday.
Been following this since you started. Looks great so far. I'm looking at picking up an enclosed trailer myself(7x14 as well)Question first. I have two standups and a blaster 1. Any idea if it would all fit? I was thinking the blaster up front centered. And the other two across the back.
Sent from my SPH-L710 using Tapatalk
Length wise. All three facing front.@afraz1er
My neg. 13" footrocket barely fit side ways in the front of the trailor threw the side door, for when we haul 4 standups. Or are you saying blaster and standups length wise? May all fit length wise depending how long those standups are.
Do you have guides for the winch rope to match up with the outside skis or do you move the winch ?
